Old 04-16-2008, 03:29 AM
Pat O'Connell Pat O'Connell is offline
Default Removing a powder coated finish
Does anyone have input/ideas as to the best way to remove a powder coated finish? I purchased a set of YH rims for my Camaro that are powder coated..they look good, but the color is a little off, and I'd rather repaint them.
Thanks!
Pat
Pat O'Connell
Old 04-16-2008, 04:10 AM
micky69396 micky69396 is offline
Default Re: Removing a powder coated finish
Find someone that can dip or chemical strip them, thats the easiest. You can some times use aircraft paint stripper on them also. Blasting is tuff to do.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 04-16-2008, 04:34 AM
Plastic media blasting.
Old 04-16-2008, 04:36 AM
Thanks Guys...I appreciate the info!
Pat
Pat O'Connell
Old 04-16-2008, 05:25 AM
Shankin Shankin is offline
We just stripped an intake by using aircraft stripper.
Old 04-16-2008, 06:36 AM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
Let me ask a stupid question.... why can't you just paint them the correct color right over the powder coat?
1970Camaro Z28
Old 04-16-2008, 06:51 AM
Not a stupid question at all..
It's a matter of the date code stampings on the rims. The powder coating filled in the factory stamped numbers/letters on the rims to the point that you can hardly see them on a couple of the wheels. Between that, and the powder coated color looking more grey than silver, is enough to get me looking at stripping them and starting fresh.
Pat
Pat O'Connell
Old 04-16-2008, 07:04 AM
That makes sense Pat...never dawned on me the code numbers would be filled in. Good luck with the project.
1970Camaro Z28
Old 04-16-2008, 07:36 AM
Nova Jed Nova Jed is offline
Eastwood has a powder coating stripper.
Old 04-16-2008, 07:34 PM
http://www.camaros.net/forums/showthread.php?t=131019
