Old 04-07-2008, 11:52 AM
goinforbroke goinforbroke is offline
Default cowl tag help
The cowl tag on my 72 Nova SS is very hard to read. It appears to have been sanded by someone when previously painted. I primed and painted the cowl and just made it harder to read. Would it be best to just wipe it clean with thinner/stripper? I'm guessing it can't be repaired. Thanks.
72 Nova SS
55 BelAir 2d sdn
77 Nova 406SB 11.50/114mph "GOIN FOR BROKE" $$$
Old 04-07-2008, 07:23 PM
PeteLeathersac's Avatar
Default Re: cowl tag help
Before doing the cleaning w/ the thinners thing, does it look at all possibile that a very light flat board hand sanding may still expose only the high spots/raised alpha-numerics of the tag?.
Good luck!.
~ Pete
Old 04-08-2008, 03:34 AM
May give that a try. The numbers and letters look like they have been knocked down somewhat, or mabe just not stamped too deeply.
72 Nova SS
55 BelAir 2d sdn
Old 04-08-2008, 05:35 PM
Hit it with some scotchbrite, lightly!
Old 04-08-2008, 06:34 PM
I wouldn't want to put a harsh sanding film to it again.
If it's off the car,soak it in a strong mild solvent like Goof Off.
Paint thinner may not be stringent enough.
If it's still attached to the car,try soaking a rag/pad the same size of your trim tag in Goof Off and lay/press it on top of it.Put a thick barrier like cardboard around the surrounding area of the TT to prevent it from touching the solvent.
You can get a repop replacement from Trim Tags Inc.,but I would'nt replace it no matter how illegible it is,honestly.
Old 04-09-2008, 03:18 AM
It's still on the car so, I probably won't replace it. Will try the goof off. Thank You.
72 Nova SS
55 BelAir 2d sdn
