Old 07-19-2007, 07:27 PM
JHS JHS is offline
Default COPO rear brake line setup
I am replacing the rear brake lines on a 69 COPO camaro and am not sure if this car had the same pressure regulator valve (I guess that's it's function) as the Z28, an in-line valve located underneath the driver's side floor pan. The car has a 05D build date, if that makes any difference. The current brake line setup does not have this valve but is a 2 piece line that mates under the driver's side floor pan rather than a 1 piece line from front to rear.
'70 L78 NOVA SS
'77 Bronco
Old 07-20-2007, 10:44 PM
Default Re: COPO rear brake line setup
Joe,
Sounds like a repair at some point. I've never seen the
rear brake line joined in the location where the valve is.
I hope someone didn't bypass that valve, if it was originally
there.
One clue to look for: Look at the location on the outer
drivers frame rail and see if the mounting location for the
valve shows any signs of one ( valve ) ever being mounted.
The hole for the self tapping screw should show signs of
threads at least.
I would think that an 05D car would have the valve in question though.
Steve
Old 07-20-2007, 11:17 PM
COPO CARTEL COPO CARTEL is offline
You have a PM
Drive it ...Like you STOLE it !!
