Old 12-31-2006, 08:03 AM
Donutblue Donutblue is offline
Default 67 Camaro Rag top Conversion
Ok, guys I just purchased this 67 Camaro Conv, it's a 6 cylinder, auto power/glide. I'm pondering to convert this to a 350 - 4spd keeping the 10 bolt rear. Multi leaf rear springs are already on the back of the car. As you can see from the photos the car is in really nice shape. Along with the conversion I would include power brakes to the front and power steering. Looking for some feedback or who may have done this before. Thanx
"I never think of the future. It comes soon enough." - Albert Einstein
Old 12-31-2006, 11:04 AM
Default Re: 67 Camaro Rag top Conversion
nice car
Old 12-31-2006, 11:20 AM
JChlupsa JChlupsa is offline
nice car
I agree with that Very Nice car and for swapping out the 6 for a V8 i would leave it with the 6. Might even find a header for it and do some engine work on it and have some fun with it. You dont see many org straight 6's around anym ore
Old 12-31-2006, 04:49 PM
kwhizz kwhizz is offline
You shouldn't waste your time on a car that so far gone...........wait for a solid one........Let me know how much and I'll come and take that "Beater" off your hands.........LOL
Ken
Old 12-31-2006, 05:42 PM
KevinW KevinW is offline
Very nice survivor! When a car is this nice, but the drivetrain is not what you want, my rule of thumb is dont change anything you cannot change back by turning a few bolts. With that in mind, the 4 speed is out, because you have to cut the hump. I would put the 350 in using bolt in parts and upgrade the powerglide to a TH350 or 200r4. That should help the acceleration blues. actually, you could put the 200r4 behind the 6 cyl and getting much better accel and GREAT gas milage and not have to change much at all! Remember to save and tag everything you take off for future owners. Have fun!
BTW, power brakes is a good swap, no too much work, But changing the steering is more involved. If you keep the 6, then the man steering should be fine
69 327 convertible (driver)
Old 12-31-2006, 06:59 PM
Rick H Rick H is offline
Yenko Premier Member
I think you have two otions here.
1. Leave it alone, add disc brakes and enjoy it or.
2. Leave it alone, sell it to me, let me add disc brakes and enjoy it.
Very nice original car and you just don't find them like that any more. Great find.
Rick H.
Old 12-31-2006, 07:07 PM
Just for informaion.
That is not true on a 1967 Camaro with floor shift automatic. The hole in the hump is the same one used for both automatics and standard shift. No extra cutting is involved and putting in a 4 speed is a direct swap. The same crossmember is also used. The driveshaft can be used as well.
Putting in a T350 is also a direct swap and uses the same crossmember. You can even use the same shifter with the T350. Just needs an extra notch added to the detent bracket.
I would leave it alone because of the originality.
Rick H.
Old 12-31-2006, 08:27 PM
I'm still tossed. I purchased the car right - prior owner won it in a raffle 3 yrs ago sponsored in a small Town by a local Chevy dealer and a radio station. He has since put 1200 summertime miles on it.Under carriage is just as sweet as what you see on top and the originalilty may hold me back from the swap.
Old 12-31-2006, 09:11 PM
I have the perfect solution to your problem. I'll just come get it and you won't have to worry about it any more. Will make a perfect match to my RS coupe.
Drive it like it is and enjoy it.
Rick H.
Old 01-01-2007, 09:30 PM
x  Baldwin  Motion's Avatar
a couple of years back I picked up a 65 malibu SS with a 6/pg from its original owner. drove it like that for a while then became bored. removed and wrapped up the six, pg,console,shifter and every nut to return to original. driving it now with 8/4spd,picked up all original shifter pedals console etc so it looks stock. retained manual steering. more fun to drive and dont have to worry about breaking the six trying to keep up with the big boys.
Chris
