Old 03-22-2026, 12:06 AM
enio45 enio45 is offline
Default Rear axle rubber bumpers
Purchased a new set of rubber pieces from HBC - sooooooo, what is the trick to getting these darn things on? Virtually impossible - so far!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-03-2026, 11:50 PM
Eddie, What year Camaro you needing to install the new rubbers............
I have a 1970 Camaro and Im wanting a pair of one year only rubbers
to fit the brkt's I already have
https://www.facebook.com/marketplace...19MXV8gyMv%2F#
Chuck Sharin
[email protected]
70 Camaro R/S Z-28, L-78
69 Camaro COPO recreation
Old 04-04-2026, 11:49 AM
mhm1966 mhm1966 is offline
What type of lubricant are you using?
1966 Corvette Coupe L79 Mossport Green
1969 Camaro Z/28 Hugger Orange
NCRS #22211
Old 04-04-2026, 02:37 PM
These are for 68/69 camaro -
The old ones when i removed them are way more pliable than the new repo ones.
I have used silicone spray, grease....
U cannot compress the sides of the triangle area of the snubber (where it secures itself to the bracket) AND insert it into the bracket......
i did not try, but the old ones will most likely compress easily enough and slide in the bracket with a little grease or silicone.
Im changing them because one fits loosely and freshing up the wheel well area.
Advise?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-04-2026, 02:38 PM
Advise?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-05-2026, 11:26 AM
R68GTO R68GTO is offline
I recall the struggle during my COPO restoration but can't quite recall the process other than using liquid dish soap as the lubricant. I may have posted something in my thread about it - getting old causes details to fade into oblivion. I just had to do the center one as the outsides were original and still good - they went in easy!
