Old 06-04-2022, 02:11 PM
scuncio's Avatar
scuncio scuncio is offline
Default Clean '66 Lemans, Orig 326/4-sp
I hate the stripes, but the seller claims this car was originally ordered with the current 326/4-speed combo and Platinum paint. Pretty sharp combo and looks very dry. But...the stripes would have to go if it were mine....
Still, not a lot of decent stuff on the market under $20k.
Link to 1966 326/4-sp Lemans auction
237176P335276
markinnaples (06-05-2022)
Old 06-05-2022, 12:21 AM
Too Many Projects's Avatar
You're right, Tony, that stripe is hideous on that car.
Wish he had the PHS, but if it was a true HO 326, the price would, most likely, be higher.
Appears the rear window, or trunk seal leak badly. Other than that, no obvious issues.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 06-05-2022, 01:45 AM
60sStuff's Avatar
60sStuff 60sStuff is offline
The last photo shows a stack of PHS papers, but that does no good if he doesn’t show the option pages.
No mention that it’s a 326 HO. That engine block code would be WR (3047 built), but no photo of that either.
I see a posi tag on the rear end.
Also ziebart plugs on body jams.
All Cordova (vinyl) tops leak terribly (numerous clip holes) from the aluminum trim which allows water into the trunk compartment.
Odd that this Lemans dash has the wood veneer. Only GTO’s came from the factory with that feature.
The Following User Says Thank You to 60sStuff For This Useful Post:
grantprix (06-07-2022)
Old 06-05-2022, 02:54 AM
Instrument panel was probably changed over the years to get the wood and tach.
15-16 years ago, I tried to buy one with the HO 326 and 4 speed. Seller claimed his dad bought it new and it was all original. Except it was in northern Iowa and was quite rusty. After the family stopped driving it with around 100k, they parked it and let it decay for 30 yrs. He was attempting to get the engine to loosen up and turn over. He wanted about the same price as a basket case GTO and wouldn't budge, so I passed and bought a '67 GTO instead. Don't recall for certain, but that one may have a been a '67 too.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
