Old 09-06-2021, 12:06 AM
Woodrock Woodrock is offline
Default 1967 Chevelle SS Pressure PS hose
Should this hose have a rubber or foam wrap over the hose to protect from damage? Was this hose made like this originally?
Found conflicting wrap info on the net while searching for a good replacement for one that sprung a leak.
Thanks.
Old 09-06-2021, 01:24 AM
No, just the hose. It comes VERY close to the inner fender, and original cars almost always have the paint rubbed off the inner fender by the hose. But no protective wrap.
Others may have correct ones now, but it used to be that Ground Up was the only vendor offering the correct shaped 66-67 Chevelle 396 (and 65 Z16) PS pressure hose. It actually passes under the pump and then comes up between the pump and the pulley. Many vendors sell an incorrect one that routes entirely behind the pump.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following User Says Thank You to jeffschevelle For This Useful Post:
Woodrock (09-06-2021)
Old 09-06-2021, 02:30 AM
Too Many Projects's Avatar
Any pics of this hose, Jeff. I added PS to my '66 a while back and had a HECK of a time finding a hose that even worked. The one on there now looks like spaghetti as it winds around.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 09-06-2021, 04:21 AM
Thanks Jeff.
Old 09-06-2021, 04:33 AM
67since67's Avatar
Attached is a visual of what Jeff said, both survivor original and a Ground Up repro.
Bill W
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
Too Many Projects (09-06-2021), Woodrock (09-06-2021)
Old 09-06-2021, 12:16 PM
Thanks, Bill. It does look similar to what I have, but I'll have to look at mine. It's been a while
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
