Old 08-02-2016, 03:22 PM
DBelk DBelk is offline
Default 1972 nova reverse lockout
Hopefully someone can help me. Have a 1972 Nova SS. Has a zz4 crate motor mated to a non original transmission. It is a 1964-1965 M20. I need the complete reverse lockout rod assembly, etc. Lights work, just nothing there to activate them. Any help appreciated. Thanks. Dave
Old 08-03-2016, 01:56 AM
JRSully JRSully is offline
Default Re: 1972 nova reverse lockout
Hurst makes a reverse light kit Used to anyway), oem reverse lockout stuff costs and arm and a leg
71 Porsche 911 Targa
Old 08-03-2016, 02:11 AM
cwc's Avatar
cwc cwc is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JRSully</div><div class="ubbcode-body">Hurst makes a reverse light kit Used to anyway), oem reverse lockout stuff costs and arm and a leg </div></div>this would be your best bet, 72 nova would have had a Saginaw 4 speed,so if you really want the lock out stuff,you need to look for 69-71 parts if you have a Muncie
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
Old 08-03-2016, 03:23 AM
OK. Appreciate the responses. So the placement of the rod assemblies would be the same on my 64-65 M20 as a 69-71M20? That is very helpful if so. Dave
Old 08-03-2016, 11:07 PM
enio45 enio45 is offline
is the reverse light switch mounted on the column like a 69 camaro??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-03-2016, 11:11 PM
earntaz earntaz is offline
Yes -- should be four terminals ... two for neutral safety sw and the other two for backup lites ... TAZ
Old 08-03-2016, 11:18 PM
You will need the reverse shift arm with the extra hole for the lockout setup...I believe the early Muncie shift arms attached differently than the later versions bolt vs washer/nut??]..so that may influence the parts selected.
wilma
Old 08-04-2016, 12:32 AM
Yes the switch is on the base of the interior side of the steering column. I only remember seeing one terminal with 2 leads. Wilma, you are correct on that little arm on the reverse lever. It is the only part of the lockout that is there. [img]<<GRAEMLIN_URL>>/smile.gif[/img] I am thinking I just need the 2 rods and the link they both connect to now. Getting closer. Thanks again. Dave
