Old 05-20-2016, 05:49 PM
Default 68-69 Camaro or 68-72 Nova Subframe needed
Looking for a nice, straight 68-69 Camaro or Nova front subframe bare or with suspension, for my 69 Z-28 Project X resto.
PM me with details.
Thanks, Paul
832-373-7740
Old 05-21-2016, 07:08 PM
the427king's Avatar
Default Re: 68-69 Camaro or 68-72 Nova Subframe needed
67 WONT WORK?
No Fisher priced toys here
Old 05-21-2016, 08:57 PM
68moz28rs's Avatar
68moz28rs 68moz28rs is offline
67 Has different holes in the front of the subframe then 68-9. It would still work though
68 Camaro 302 Z/28 Rally Sport
68 Camaro Convertible w/427
68 Camaro Drag Car
67 Camaro Royal Plum RS/SS
67 Camaro Convertible 327 RS
92 Corvette Convertible Quasar Blue white top
http://www.ebay.com/sch/usa-1musclec...pg=&_from=
Old 05-21-2016, 10:11 PM
the427king's Avatar
I believe the very early 67s had no hole,and after that they were all the same..
Old 05-22-2016, 03:03 AM
Woj's Avatar
Woj Woj is offline
I would think that shouldn't be too difficult to find one near you. The subframe is good up to '74 Nova as I recall from Hollanders. Some of the off-brands like Buick, Olds, Pontiac had some funky brackets welded on them but the same otherwise.
Good luck.
Old 05-22-2016, 04:17 AM
WorkinProgress WorkinProgress is offline
'67 frames have the lower A arm bumper attached to the subframe not on the A arm like '68 and '69s. 1968 has the A arm bumper on the backside of A arm. 1969 has the A arm bumper on the front side. 1969 has two subframes. One was used up till around August of 1969 and the revised version after that for the late build '69 Camaros or the 1970 Nova.
- Warren
Old 05-22-2016, 03:58 PM
enio45 enio45 is offline
Warren,
can you tell me more about the differences on the 69 subframes?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 05-23-2016, 04:09 AM
Eddie, the easiest way to tell a late '69 Camaro frame or '70 up Nova is by looking at the driver's side front top three holes. The forward hole is used for the radiator support mounting. The third rearward hole will be elongated on the later frames. From what I was told, but never checked to verify is it was elongated for the vent hose used with the charcoal canister on the Nova.
- Warren
Old 05-23-2016, 11:13 AM
KevinW KevinW is offline
Paul, talk to this guy in Colorado, maybe you can work something out.
http://www.camaros.net/forums/66-wha...nsion-etc.html
Fresh Professionally Built original 68 327 Camaro RS
Engine 327 .030 over, line honed, Maule coated pistons 10:1, Double hump heads, Comp cam, rocker roller and all accessories shown, intake air cleaner, alt, A/C compressor, headers, electronic ignition, starter, wiring harness, etc
Subframe, powder coated, new bushing, bearings, seals, springs
Quick ratio gear box
radiator and shroud
Disc brakes, brake lines, rear drums, master cylinder all new
1961 date coded, T10 four speed, rebuilt, new clutch, aluminum flywheel
(The car was originally an auto)
12 bolt rear 3.73 fresh rebuilt and powder coat
drive shaft
2.5 inch exhaust never installed
What's it worth!
69 327 convertible (driver)
Old 05-23-2016, 02:37 PM
thanks for the info Warren
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
