Old 05-10-2015, 12:51 AM
jasonL78 jasonL78 is offline
Default Pontiac 400 exhaust manifold help
Figured I'd ask my question here.
Ok Im working on a 70 TA with a 400. It has these huge stock manifolds 3 bolts per side which blows my mind. I'm used to SBC with 6 per side. I bought the stock fel-pro metal gaskets which are real thin. It only solved my leak on passenger side. The driver side is leaking real bad on center port and back port. So today I pulled the driver side manifold off and it was real rusty from years of leaking by. So I put a straight edge across the face of manifolds and the center port is low. So it looks like it is warped some. I tried to true it up the best I could. Installed back into car and still leaking. I'm thinking a thicker gasket will solve my problem what has everyone used.
Looking for the next project.
Old 05-10-2015, 01:02 AM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
Default Re: Pontiac 400 exhaust manifold help
some machine shops can mill them flat again
Old 05-10-2015, 01:09 AM
Ya that's going to be my last resort.
Old 05-10-2015, 02:08 AM
L78steve L78steve is offline
Its the only solution.
Old 05-10-2015, 03:11 PM
Wakepowell Wakepowell is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">Its the only solution. </div></div>
Not the only solution, you could buy replacement from Ram Air Restorations
Old 05-10-2015, 04:50 PM
earntaz earntaz is offline
Take them to any good machine shop and have them milled -- keep the original part(s) ... TAZ
Old 05-10-2015, 05:29 PM
I had a pair of SD manifolds cut. Not cheep due to the set-up but came out perfect.
Old 05-10-2015, 06:07 PM
marxjunk marxjunk is offline
id leave them alone..put them up and keep them for the car, and buy a pair of repops..not the ebay/parts place stuff..RARE manifolds as stated above
Mark
