Old 07-31-2014, 04:08 PM
Zman1969 Zman1969 is offline
Default restore fuel lines?
I have gotten a BB fuel line with Y-block and bracket orig off a 69 Chevelle that was taken off in first couple years I have cleaned it with laquer thinner but wondering what would be safe as not to destroy the original finish on it? I was thinking scotchbrite but that may be too much- fine steel wool?
thanks guys
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 07-31-2014, 04:13 PM
Default Re: restore fuel lines?
I would think 0000 steel wool with WD40/Liquid Wrench for lube would work well...shouldn't leave any scratch marks. Of course, some of the resto gurus may have a better plan.
wilma
Old 07-31-2014, 04:29 PM
Scotchbrite or steel wool will both put a polish on them so I do not use either. I soak mine in Nutro-Rust or the equivalent. However, I have never tried cleaning brass in there so not sure of it will clean that up.
Old 07-31-2014, 04:59 PM
Rick...could they be beaded with fine plastic or soda?
Old 07-31-2014, 05:53 PM
SS427 say something like Evaporust?
Wilma that sounds like would work but finding the material or somethat that would spray it may be an issue
I wonder how Tarn-X would do on the block?
90 Formula 350
Old 07-31-2014, 09:55 PM
0000 steel wool. will dull back up good enough. if it is not a one of one car I would not hesitate to use the steel wool.
Old 07-31-2014, 10:07 PM
Enoch Enoch is offline
Banned
A very dull and oily wire wheel brass or steel VERY light touch. The worn wheel wont scratch it (start with a fine grade wheel) and the oil in the wheel leaves a natural patina to it.
NOTE: oil and dirt from dirty parts on the wheel work best. I keep one wire wheel in the shop for initial clean up of hardware and it stays with a fresh coat of oil/dirt to do the trick.
Old 08-01-2014, 02:09 PM
Yes to Evaporust and plastic media works REALLY good. Just hard to find someone to do it in a lot of areas of the country.
