Old 08-17-2008, 06:03 AM
P.J. P.J. is offline
Default gauge cluster help
My 70 chevelle gauge cluster,water temp guage did not work so
I changed it. the car has a new wiring harness from factory fit, also enjine harness is new. After changing the new GM NOS gauge it still does not work
I made sure that the new gauge was installed correctly
and there is a new printed circuit installed.
I checked the heat plug on the motor its seems to be ok
and still the gauge does not work
any Ideas on how to fix the problem. Do those heat switches
on the motor ever not work??
PJ
Old 08-17-2008, 07:04 AM
enio45 enio45 is offline
Default Re: gauge cluster help
Do you have continuity from the engine harness to the gauge?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-17-2008, 04:32 PM
Ed
I have not checked that,But i will what should I expect when I check it.
PJ
Old 08-18-2008, 08:07 AM
you should have continuity - so the signal from the engine sensor goes to the gauge. Do you have a wiring diagram for the car - it should show you the wire path from the engine sensor thru the harness and its connectors to the gauge point of contact. Without continuity in the wire - the gauge will never register the temp.
Also - if its a new harness - (i'm just guessing here), but are the harnesses ordered for specific type gauges? First order of business is check for continuity from the point of the engine sensor thru the fuse block to the gauge connection point.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-18-2008, 10:54 PM
Ed
They are new gauge harnesses in and out.
I have checked the gauge itself and there is continuity . I am going to change the switch first. Then I will follow your advice thanks
PJ
