Old 07-18-2008, 01:14 AM
69Tom 69Tom is offline
Default 1969 Camaro (COPO) steel wheel paint
I was wondering if anyone could enlighten me on how the stock steel wheels were painted on a '69 (the wheels used with the dog dish hubcaps).
Only half was painted the color or the car, correct? Should I use a clear coat over them to protect the paint? Should it be sanded down and more than one coat of clear used?
I'm just curious as to how much time was spent on these. I'm guessing it wasn't much, but they were also using a one step paint, so there was no clear to deal with. Wondering how people who do concours restos treat them now....
Old 07-18-2008, 02:03 AM
Default Re: 1969 Camaro (COPO) steel wheel paint
I sprayed mine with a single stage urethane on the front side only, making sure some of it blew through to the backside.
Old 07-18-2008, 02:43 AM
Thanks, Marlin. I guess the problem is, I'm painting them at the same time as the rest of the car, and I'm using a base coat/poly. Your method, however, I'm guessing is the proper way to paint them.
Old 07-18-2008, 03:12 AM
BARRY BARRY is offline
HI paint them the same as the car any base clear paint will be 5 times better than factory paint
Barry Allan
Old 07-18-2008, 07:29 AM
Mr. Chevy's Avatar
DITTO on mine as well
Rich
Old 07-18-2008, 05:37 PM
I painted my car with base/clear, but got a pint of single stage mixed up just for the wheels and overspray areas so I would have to mess with the clearcoat in those areas. I was afraid that I would get clearcoat on the non-painted areas and it would look hokey. So, I sprung for a pint of single stage.
Old 07-18-2008, 06:16 PM
Bob Bob is offline
I just painted my steel wheels and underside overspray with single stage. I have debated back and forth about what to use on the car body and had decided on single stage. After reading Marlin's post, it looks like the debate continues.
Old 07-18-2008, 06:31 PM
I no paint expert, but have received advice that single stage is just fine for the life that these cars will receive. It's easier than 2 stage!
Old 07-18-2008, 09:16 PM
firstgenaddict's Avatar
The problem with single stage (especially metallics) they are incredibly difficult to touch up and blend... you can panel repair them if you keep extra paint but spotting in catlyzed enamel is next to impossible!
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 07-18-2008, 10:29 PM
Bob Bob is offline
I've read a fair amount but have little practical experience when it comes to painting. From what I've read, you are right on about the metallics; for non-metallics there seems to be pros and cons about single stage vs. BC/CC and comes down to what the painter likes best based on his personal preference.
