Old 07-14-2008, 07:18 PM
CanadianPoncho CanadianPoncho is offline
Default Converting from idiot light cluster to gauges
I'm in the midst of converting the standard idiot light cluster on my 69 Pontiac Laurentian (Catalina body on Impala chassis) to a "rallye cluster" which has oil, temp and amp gauges from a 69 U.S Bonneville. I converted the pin locations on the harness plug to match the Bonneville. That went smooth. I plugged in the new cluster and have the following problems:
The gas gauge only reads 1/4 even though there is half in the tank.
Does anyone have a GM parts book who could look up the PN of the sending unit to see if the rallye cluster cars got a different one? Not sure if this makes a difference, but I did an Ohm reading of the new gauge vs my old gauge and the new one has 20 Ohms higher resistance.
Also, my oil pressure reading is only about 12lbs cold. I swapped the idiot light sender with a Chevy gauge unit (new). Did Pontiac use different sending units for their oil pressure gauges?
I also swapped the idiot light temp sender with one from a 68 Nova and the temp guage reads full hot as soon as I turn the key on. I assumed that GM would have standard oil and temp sending units across the board but now it seems I am wrong.
I appreciate any help! It was a real pain pulling the cluster and I'd hate to have to put the old one back in. Here's a pic of the Bonneville cluster. They are pretty rare:
Todd
The Canadian Pontiac forum:http://www.canadianponcho.ca
The 2 Door Post forum
http://www.2doorpost.com
Old 07-25-2008, 07:22 AM
67BobcatGTO 67BobcatGTO is offline
Default Re: Converting from idiot light cluster to gauges
Hi,
The fuel sending units are the same whether you had standard or ralley gauge clusters. The gauge and/or sending unit is out of calibration. You should have both units re-calibrated together to insure an accurate reading.
Pretty much all GM gauges after 65 were air core technology and used a 0-90 ohm scale. Most new senders you can get now are junk. I have had good luck with the ones sold by Lectric Limited.
Pontiac had two different oil senders in the 60's one for a 60lb and one for an 80lb gauge. For 69, you'll have an 80 lb gauge so make sure you have the right sender.
It would be a good idea to have the gauges checked before buttoning up the dash.
I'd be happy to help with any questions/problems you might have.
Thanks
Mike Mancini
www.instrument-specialties.com
