Old 07-11-2008, 08:13 PM
JIM's Avatar
JIM JIM is offline
Default 68 Camaro MQ engine carb to pan Vin # 8N326074
I have a mostly complete original 1968 Camaro 396-375 HPengine out of SS396 Vin # 326074. The MQ stamping is T1004MQ. The block is casting 391323 date I-23-67, the crank 6223, the water pump 3856284, H-23-67, the heads 3919840 H-24-67, H-24-67, the intake 3885069 . The block has been magnifluxed and is fresh 60, over correct pistons and dimple rods. Ths was a fresh rebuilt engine that I had dissassembled for inspection it just needs reassembly. I had the waterpump rebuilt. The original intake had the pleninum cut out so I got a correct one that is dated earlier than the engne that has not been touched. The carb is 4053 8B3 and is nice as well. Correct timing cover, oil pan and balancer. I used the dist but have the pulleys available seperately if someone is interested. I am tring to upload pictures to the add. I hope this may find its way back to the original car. The price is $5700.00.
please call Jim at 302-420-4743
Old 09-09-2008, 06:57 AM
JIM's Avatar
JIM JIM is offline
Default Re: 68 Camaro MQ engine carb to pan Vin # 8N326074
Reduced the price to $5000.00 before it goes to e-bay !!! Jim
