Old 06-24-2008, 10:53 PM
jeff-san jeff-san is offline
Default 72 Z-28 parts
still looking for the last remaining pieces:
- dist 1112095
- exh manifolds/smog set up
- white door panels front/back
- VF3 front/rear bumpers or replacement inserts
thanks
Old 06-28-2008, 02:05 PM
TDW TDW is offline
Default Re: 72 Z-28 parts
What are the casting numbers on the exh manifolds that you need? I have a set of 041 and 562 with a Jan 72 date if I remember correctly.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 06-28-2008, 06:13 PM
- dist 1112095
- also need a rear defroster motor
thanks
the car was assembled 01B if that helps
Old 08-28-2008, 05:57 PM
found a few of the pieces...still looking for the following
- dist 1112095
- exh manifolds
thanks
