Old 06-19-2008, 08:17 PM
ktownkid ktownkid is offline
Default Intake Oil Filler---Block Off
Hello,
Well, I finally found a C3BX intake that I liked, though it is dirty. My question is, I want to block off the oil filler tube location at the front of the intake. Everyone says to use a freeze plug. Do you have to use some kind of gasket to prevent oil or air leaks???
I have also heard a freeze plug is the wrong thing to use, but what would you use if not a plug???
Thanks----
ktownkid
Baseball, Hot Dogs, Apple Pie and Chevrolet
Old 06-19-2008, 08:21 PM
John Brown's Avatar
Default Re: Intake Oil Filler---Block Off
1 1/4" freeze plug, metal or the expandable rubber kind.
John Brown
Old 06-19-2008, 08:27 PM
budnate's Avatar
budnate budnate is offline
and a little black RTV sealant
Old 06-20-2008, 02:48 AM
Make sure you get the plug set straight in before you hammer on it because if it is cocked just a little bit you can crack the intake.
Old 06-20-2008, 10:13 PM
Thank you all. I just may take this to the machine shop and let them do it.
Thanks again.
