Old 06-19-2008, 05:32 AM
Fast67VelleN2O's Avatar
Default All GM Nationals Parts List....
I'll be at the GM Nationals Thursday-Saturday Afternoon in spaces M56, 57, and 58.
68-72 Chevelle 12 bolt posi rear, 3.90 Richmond gears, GM 3 series unit, painted black, new seals, looks nice and feels good $875 obo
67-69 Camaro or 68-74 Nova 8.5" 3.42 posi rear, GM gears and unit. Nice shape, painted black $575
660 Case M20 Muncie, no broken or chipped teeth, engagement teeth on input are a little worn, has new gasket set installed, I believe this is a 68 trans, have to check $500
1963 Muncie M20, nice shape, 704 case, new gaskets, good gears $475
64-65 325 case Muncie M20, recently freshened up with new input shaft, blocking rings and small parts, run for 10K miles, then switched to an M22. New gaskets just installed. $500
Super T10, 3.42 first gear, nice gears, good used unit $475
1971 402 block, standard bore, 2 bolt, comes with pistons and rods, some rods are missing main caps, good shape, doesn't appear to be any cracks, been sitting in my garage since the early 1990's. $225
4 "AG" Ralley Wheels. Need to be cleaned up $125 set
NOS GM 82-92 Camaro driver's fender for ground effect equipped cars $125
lots of other parts. Stop by and say "hi"
Day 2 is Life.
