Old 06-11-2008, 06:32 AM
Default Zinc & solid Lifters
Is there any opinion on the effects of non zinc oil on high performance cam wear. I have read that modern motor oils do not offer protection for solid lifter/cam.
Does or has anyone used "Oil Extreme Concentrate" in their motor???? I have read that this product offers the same wear protection as zinc.
Carl
Old 06-11-2008, 07:47 AM
Default Re: Zinc & solid Lifters
My engine builder tells me that I need to run zinc oil like Rotella T in all our engines or I will suffer premature wear.
Old 06-11-2008, 03:44 PM
firez firez is offline
I use Valvoline VR-1 oil in my 68 solid lifter Z28. It is very high in zinc
1968 LOS Rallye Green Z28
Old 06-11-2008, 05:00 PM
Everyone around here uses VR-1 too.It really is the most economical and best solution I think.
Old 06-11-2008, 08:27 PM
ktownkid ktownkid is offline
What is "Brad Penn" oil??? Have a chance to get a few cases locally. I understand it has a high zinc content, but I have never heard of it.
Thank you in advance.
ktownkid
Baseball, Hot Dogs, Apple Pie and Chevrolet
Old 06-11-2008, 08:37 PM
Brad Penn is Pa. based and comes from the old Bradford, Pa. wells. Same composition as Kendall GT-1 of old. Go to Yahoo search and type in Brad Penn. I use it and also Rotella-T. P.S. I think we discussed this in length not to long ago. In technical and Resto under motor oil.
Old 06-11-2008, 09:35 PM
Previous discussion
Old 06-11-2008, 11:34 PM
Thanks Rick,
Guess I should have searched first.
Thanks for the help guys
Carl
Old 06-12-2008, 02:15 AM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
Not everyone Rick....I use Rotella and I had the foresight to stock up on the old Rotella with the API rating of CI-4. The new Rotella has a new API rating of CJ-4 which I understand has a lower level of zinc but still has more zinc than conventional moror oil. When my supply of Rotella runs dry(which should take several years) I too will probably switch to the Valvoline VR1.
1970Camaro Z28
Old 06-17-2008, 09:20 PM
JRSully JRSully is offline
What weight is applicable in the Valvoline VR-1 for a solid lifter BB.? Thx
71 Porsche 911 Targa
