Old 06-04-2008, 09:43 AM
Rainer Rainer is offline
Default Bunch of 68-72 Chevelle parts for sale
Lots of 68-72 Chevelle parts for sale. These are all good quality parts – the junk went to the scrap yard. Here’s a partial list of what is available:
Interior parts
- 70-72 front arm rests, black and several other colors, all in nice shape, mounting screws included, $15 each
- 70-72 rear arm rests, black, vinyl-covered metal ones (not plastic) that were in 70-72 Monte Carlos, direct swap into a Chevelle, $40 pair.
- 70-72 front stereo speaker brackets, $25 a pair
- 68-72 inside A-pillar cover, no rust at the lower corners as is common, $15 each
- 68-72 black kick panels for AC cars, $30/pair
- 70-72 front windshield or rear window inside trim, nice with no cuts from glass removal, black and several other colors, $25 each
- 68-72 gas pedal assembly, $10
Exterior trim
- 70 grill stainless trim, original GM pieces. These are the C-shaped ends. Set of 4 for $40
- 72 headlight bezels, no pitting, $30/pair
- 68-72 front windshield stainless, driver quality with only a minor ding or two, $15 each side piece, $25 for top piece
- 68-72 rear window stainless, driver quality with only a minor ding or two, $15 each piece
- 68-72 drip rail corner pieces. These are the ones at the top of the A-pillar, $5 each
- 68-72 drip rail A-pillar stainless trim, runs down the pillar between the windshield and door glass, driver quality with a couple small dings that could be easily taken out, $10 each
Miscellaneous parts
- 68-70 factory Muncie bench seat shifter handle with GM part number stamped into it, needs to be rechromed but ball threads are good, $75
70-72 door latches, good working condition, $15 each side
- 70-72 door window regulators, good working condition, $10 each side
- 70-72 quarter window regulators, good working condition, $10 each side
- 68-72 rear frame crossmember, nice straight piece for replacing that bent-up piece on your car, has been cut off past the frame rails so you can trim and swap in at the factory seams, $40
- 68-72 upper front control arms, no road salt rust, $25 each
- 68-72 lower front control arms, oval rear bushing, no road salt rust, $35 each
- 68-72 upper rear control arms, no road salt rust, $10 each
- 68-72 lower rear control arms, no road salt rust, great pieces for boxing up, $20 each
- 70-72 door glass, $10 each
- 68-72 door hinges, $15 per side (upper and lower)
- 70-72 front bumper filler panel, $60
- 68-72 gas tank straps, these are straight, rust-free originals with the correct stepped and narrowed ends (the current GM replacements are different), $45/pair
Parts will be shipped for actual cost through FedEx ground. Pics available for some parts, but please don’t ask for them and waste my time if you are not serious. Paypal OK if you don't mind covering their fees. Otherwise check or MO is fine. Email me at [email protected] Also have additional parts not listed – just ask.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 06-04-2008, 06:28 PM
68Biscayne427 68Biscayne427 is offline
Default Re: Bunch of 68-72 Chevelle parts for sale
I'm interested in the 68-70 factory Muncie bench seat shifter handle.... Could I get a pic before I commit?
Thanks - Rob M.
email - [email protected]
Rob M.
'68 L-72 Biscayne, M22 4-speed
Old 06-04-2008, 06:37 PM
Pics of Muncie handle sent.
