Old 06-03-2008, 07:28 PM
Stefano Stefano is offline
Default 427 Race Engine and trans out of a COPO Camaro
427 ENGINE FROM 1969 COPO RACE CAR FEATURE CAR JAN 05
Freshened up 80 miles and about 20 passes since 2003 Ran 10:50's with ET STREET TIRES
DYNO RUN 9/28/2002 MAX POWER 515.0 MAX TORQUE 411.3
1977 REPLACEMENT BLOCK 4 BOLT MAINS
BORED 30 OVER STEEL 427 CRANK 3/8 CONNECTING RODS
OPEN CHAMBER LIGHT WEIGHT MANLEY PISTONS 12 to 1
COMPRESSION ASSEMBLY BALANCED
IRON OPEN CHAMBER LS7 HEADS WITH STAINLESS VALVES
MOROSO OIL PAN WITH WINDRIGE TRAY
ROLLER ROCKERS
STUD GIRDLES
SOLID ROLLER CAM BY COMP CAMS 782-720 LIFT
EDELBROCK TARANTULA INTAKE WITH HOLLEY THAT FLOWS AT 930 CFM
ELECTRONIC BLUE HOLLEY FUEL PUMP
GM HY TORQUE STARTER
ATI DAMPER
ORIGINAL HEADERS FROM 1969
STEEL 45LB FLYWHEEL
11 RAM PADDLE CLUTCH
11 RAM PRESSURE PLATE
STEEL BLOW PROOF BELLHOUSING
ALSO HAVE JERICHO TRANMISSION WITH HURST VERTIGATE SHIFTER FROM SAME CAR.
$8,500.00
Call Dave Steinberg 815-341-7597
