Old 06-01-2008, 03:00 PM
MR-427 MR-427 is offline
Default 1967 1968 CE NO VIN BLOCK 396 375 HP EBAY
I HAVE A NO VIN..CLEAN PAD 396 375 HP STANDARD BORE 4 BOLT BLOCK..DATED F-8-7..GOOD FOR JUNE -JULY BUILT 396 375 HP CAMARO CHEVELLE..ALSO A CE REPLACEMENT FOR EARLIER 3902406 CASTING BLOCK..ALSO CORRECT FOR 1968 CHEVELLE CAMARO NOVA 396 375 HP STAMPED TO67 ON OILPAN RAIL..CASTING NUMBER 3916323..ITS BEEN MAGGED AND PRESSURE TESTED..GOOD TO GO..RESERVE MET AT 2500.00...DELIVERY POSSIBLE...EBAY AUCTION 290235189030.
Old 06-01-2008, 03:29 PM
bennettracing bennettracing is offline
Default Re: 1967 1968 CE NO VIN BLOCK 396 375 HP EBAY
This should help http://cgi.ebay.com/ebaymotors/ws/eBayIS...A:IT&ih=019
Old 06-01-2008, 08:30 PM
BLOCK IS SOLD..THANKS.
Old 06-02-2008, 06:38 AM
turbojet427 turbojet427 is offline
I saw this post and wanted to ask a questions about a motor that I purchased a couple of months ago. I was able to find a complete L-78 minus carb and intake. Its a "CE" stamped motor early 1971 casting. The motor is absolutely perfect with only 12,000 miles. Dissassembled in 1974 to be built as a race motor; it was oiled up and never assembled again. The cross-hatch is still in the cylinder walls. Being a "CE" motor does it have good value?
