Old 05-26-2008, 12:26 AM
Draginwagon Draginwagon is offline
Default No Power from Starter out- - - Any Ideas - help !
Went to start my 454, and NaDa. No Power at all, No interior lights, nothing. Checked the battery, and it's fine. Check connections all seem fine. 12 volts going to the starter, Ok. Nothing coming out of Starter. No power at all.
installed NEW Starter. Same thing. 12 volts going in, and Nothing coming out. No power at all.
I am cleaning the ground connections on the car as we speak.
hoping that is the issue. But it is a Clean and detailed engine compartment.
Any Ideas???? Any help greatly appreciated.
Thanks
<font color="red">Dragin Wagon</font>
1970 LS-5 Townsman Station Wagon
Old 05-26-2008, 12:37 AM
John Brown's Avatar
Default Re: No Power from Starter out- - - Any Ideas - help !
If the ground cable goes to the alternator bracket, check the bracket mounts too. I've seen them have all three attachment points corroded and rusty. Makes diagnosis hard to do. May be easier to just move the ground cable.
John Brown
Old 05-26-2008, 12:43 AM
There is a grond to the block and the radiator support. The support is powder coated and might not be making a great connection. And I think your right, rust could have formed behind the ground on the block.
I'll give it a try.
Thanks
Old 05-26-2008, 05:01 AM
Cleaned and checked all the grounds, and still no power coming from New Starter motor and solenoid.
Checking every wire and connection.
12 plus volts before the starter, nothing coming out. Don't know why.
Old 05-26-2008, 06:37 AM
What do you mean power coming out of the starter? Does this car use a junction block on the firewall to distribute power to the ignition switch?
Old 05-26-2008, 07:10 AM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
check the 10? guage wire junction block behind the battery on the rad support.
Old 05-26-2008, 07:24 AM
Sorry, junction block on the core support is what I meant. That is the most common cause of the situation you are describing.
Old 05-26-2008, 07:43 AM
Power does not come out of the starter. Where your positive cable bolts to the starter there is another large, probably 10 guage wire that probably goes to the junction block mentioned behind the battery.In essence, the wire simply takes it's power for the car from the positive battery cable.
Old 05-27-2008, 12:45 AM
Thanks Guys,
The junction block from the positive terminal that is under the passenger side fender was the issue, couldn't see the Broken wire. My wife traced it with the schematics and found the problem.
Back runnin' Like a Bear Now.
Thanks again for everyones help.
Great Bunch. . . .
