Old 05-16-2008, 07:31 AM
LITTLE TOMMIE LITTLE TOMMIE is offline
Default BIG BLOCK WHAT IS IT
can someone tell me what this is, casting number look like 3999289
numbers on pad are T0405CWL. i was told it is a 454 out of a early impala.
Old 05-16-2008, 08:28 AM
JChlupsa JChlupsa is offline
Default Re: BIG BLOCK WHAT IS IT
www.mortec.com
3999289....454.......71-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps
http://www.nastyz28.com/gm-chevy-cod...-suffix-13.php
CODE YEAR MODEL CID HP TRANS MISC
CWL 1973 Chevrolet 454 250 TH
Old 05-16-2008, 08:48 AM
289 blocks are thick walled. You can bore 125 over with no problem. Very good race blocks.
Old 05-16-2008, 09:16 AM
thanks! you guy's very much for the help
Old 05-16-2008, 11:41 PM
396L35's Avatar
396L35 396L35 is offline
There all good race blocks but the best ones are FREE!!!
Mark
Old 05-17-2008, 03:42 AM
this motor is in this car
http://www.novas.net/classifieds/sho...p?product=2615
Old 05-17-2008, 04:07 AM
Photo of engine bay shows a small block radiator shroud and cover heater hoses are in the correct position. Check the core support to make sure it has the large opening...pinstripes are the 1970 style as far as I have seen...sounds like a fair price if it is real.
wilma
Old 05-17-2008, 08:35 AM
i have the protecto plate for it, also the GM quarters are 70's. the were not making the 69's any more at that time so those were all they could get.
the radiator still has the tag on it, but not sure if it's the right 1. the tag has ( ZD ) CODE ON IT
Old 05-17-2008, 09:52 AM
ZD is correct code for BB man. trans. those tags are only clipped on...you should take it off "carefully" and keep it with the POP...the correct rad cover is available reproduction. Good luck.
wilma
