Old 05-10-2008, 05:25 PM
firez firez is offline
Default 1968 z28 manual steering
How you adjust a manual steering box to make the steering a little tighter? Thanks
1968 LOS Rallye Green Z28
Old 05-10-2008, 11:17 PM
StriperSS StriperSS is offline
Default Re: 1968 z28 manual steering
There's an adjuster screw on the top of the box, inside a nut. You loosen the nut slightly, and with an Allen wrench, tighten the screw, no more than 1/8 of a turn. Then retighten the nut without tightening the screw. It's a 2 hand job.
It's there to compensate for wear. Any more than that and you'll need to rebuild.
Old 05-10-2008, 11:41 PM
thanks I will give it a shot
