Old 04-28-2008, 03:57 AM
sixtiesmuscle sixtiesmuscle is offline
Default '67 Camaro specs
Does anyone have ,or, know where to find accurate weight, length, width & wheelbase numbers for a '67 Camaro. Thanks
Old 04-28-2008, 04:33 AM
Default Re: '67 Camaro specs
Here's what I found in the 1967 Chevrolet Salesmans Album:
Width-72.5"
Height-51.0"
Length-184.6"
Wheelbase-108.0"
Curb Weight-*
*2,910 lbs for the 6-cylinder coupe
*3,070 lbs for the 8-cylinder coupe
*3,165 lbs for the 6-cylinder convertible
*3,325 lbs for the 8-cylinder convertible
Then add:
+21 lbs for power windows
+20 lbs for the folding rear seat option
+86 lbs for air conditioning
+9 lbs for power brakes
+33 lbs for front disc brakes
+10 lbs for the 250ci 6-cylinder engine
+39 lbs for the 327ci V8 engine
+72 lbs for the 350ci V8 engine
+258 lbs for the 396ci V8 engine
+7 lbs for the four-speed manual transmission
+14 lbs for the Powerglide automatic
+56 lbs for the Turbo Hydra-Matic
+38 lbs for dual exhausts
+29 lbs for power steering
+15 lbs for heavy-duty battery
+8 lbs for an AM radio
+9 lbs for an AM-FM radio
+17 lbs for the Rally Sport option.
Old 04-28-2008, 05:02 AM
Thanks Rick, but, does it make sense that you would have to add 258 lbs. for a 396 over a 350? That means that my big block RS would weigh only 93 lbs. less than the advertised weight on my '68 GTO.
Old 04-28-2008, 05:48 AM
I read that as only adding 186 lbs. more for a 396cid over a 350cid,but I understand what you're saying Mike.
Old 04-28-2008, 05:53 AM
Thanks. Math isn't my strong suit, but, the numbers still don't make any sense to me. I appreciate the help Rick.
Old 04-28-2008, 06:50 AM
What RS big block ?????
