Old 04-24-2008, 01:43 AM
427TJ's Avatar
427TJ 427TJ is offline
Default Hurst shifter sticks
Hope this isn't a dumb question but do all Hurst shifter sticks interchange on Hurst shifters? I want to put a taller, bent-back stick on a Super Shifter III.
Old 04-24-2008, 02:03 AM
HiHorse HiHorse is offline
Default Re: Hurst shifter sticks
if its a bolt on then I don't think it would be a problem
Old 04-24-2008, 04:17 AM
budnate's Avatar
budnate budnate is offline
pretty much, my '55 had some goofy bench seat arm and I bought a pile of diff bends last winter, the one I liked is the same arm we use on the first gen Camaros with a hurst comp plus and console, landed perfect right by the leg.
Old 04-24-2008, 04:33 AM
427TJ's Avatar
That's what I was wondering. I'm putting the Super Shifter 3 in my '55 (no console, '67 Camaro buckets) and the short stick on the SS3 is a little too short. Summit has a bunch of replacement sticks and the one I want should put the handle right where it should be.
Old 04-24-2008, 09:12 AM
budnate's Avatar
if not a little heat down low and tweek here and there should dial it in, or drive the heap up here and try out the ones I have to see if you like.. before ordering.
