Old 04-19-2008, 09:11 PM
Default Electrical Question...
When I disconnect the positive cable from the battery on one of the cars there is a good size spark discharge if the cable end touches ground. What would cause this to happen..???
wilma
Old 04-19-2008, 09:33 PM
MosportGreen66's Avatar
Default Re: Electrical Question...
I'm no scientist, but isn't this because you're still completing the circuit? The metal the negative end touches has full range of electricity because the positive cable is providing the charge from the battery.
Old 04-19-2008, 11:30 PM
firstgenaddict's Avatar
Usually indicates that there is something left on... there is definatley a drain somewhere...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 04-20-2008, 12:31 AM
wilma
[/ QUOTE ]Tom, You are saying when you take the positive cable off the battery and touch it to ground there is a spark?
Old 04-20-2008, 02:02 AM
Yes...that's what happens. There is also a strong spark when you reconnect the positive cable to the battery terminal. I notice a little spark with the other cars, but this is much stronger. Something must be on our shorting out somewhere....everything works fine on the car...no problems
Old 04-20-2008, 04:09 AM
moparts moparts is offline
1st of all never take the pos. cable loose from a battery 1st. If you take the ground loose 1st and your wrench hits ground there is no sparks. If you take the pos. loose 1st and hit ground you have a arc welder.
Anything that stores voltage (condensor, possible radio capistors etc.) can cause a spark as you mentioned. Anything drawing any voltage at all (alternator, clock etc) can cause a spark when connecting battery back.
20 foot 75 hp good time at the lake
Old 04-20-2008, 05:06 AM
Don't yell at me...I'm just a country boy anyway, my friend Sam Scardino handles my protection...you know how Italians are Thanks for the input..I will try neg first and see what happens...
wilma
