Old 04-08-2008, 02:38 AM
firstgenaddict's Avatar
Default Teflon tape on flare fittings
I see lots of resto's with teflon tape on the flare fittings... fuel lines and sometimes brake lines... can anyone explain this to me? I have never seen teflon tape cure a flare fitting leak...
Also do the judges dock points for it?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 04-08-2008, 02:46 AM
Belair62 Belair62 is offline
Default Re: Teflon tape on flare fittings
Makes no sense. A bad flare is a bad flare.
Old 04-08-2008, 02:56 AM
JoeG JoeG is offline
Also teflon tape softens and breaks down when it comes in contact with any kind of solvent or petroleum based fluid ...........Use the blue paste used on natural gas and oil fittings if you feel it necessary to use anything...But flare fittings in most cases are not very forgiving if the flare is bad as Belair said...
Old 04-08-2008, 03:51 AM
TDW TDW is offline
Threads on a flare fitting do nothing as far as sealing. The seal comes from the taper of the pipe or tubing being pressed into the sealing surface of the fitting. A thread lube is a good idea on the threads just to prevent galling and make the flare nut tighten down a little easier.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-08-2008, 03:52 AM
The nut doesn't seal, it just holds the flare surfaces tightly together so that they don't leak. Bad flare, bad leak. It's not a pipe thread.
Old 04-08-2008, 03:54 AM
Steve Shauger's Avatar
Administrator
Teflon tape was not originally used, and is not needed in a flare fitting application.
www.vintagecertification.com
Old 04-08-2008, 04:38 AM
69 Post Sedan's Avatar
Plus if the tape tears and gets into a line it could plug the line. I was priming a motor I rebuilt. I used teflon tape on the threads for the oil gauge. At first I wasn't getting a pressure reading on the gauge. When I removed the gauge, the tape was covering the small hole for the gauge.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-08-2008, 05:02 AM
OK --In a ****quick fix ****if the flare is just having a problem seating against the face of the nipple fitting and unless the flare itself is not split or chipped--wiping some blue paste on &amp; around the **face** NOT threads of the nipple fitting usually stops the leak----------I've had to make ***temporary repairs*** in a pinch ------Replacing a worn flare fitting is the proper procedure for a permanent repair--------save teflon for the faucet. ......
Old 04-08-2008, 06:01 AM
<font color="blue">I've seen a locking compound on threads so they do not back off. Not for sealing though. </font>
Mike Fabian
Old 04-08-2008, 06:33 AM
bkhpah bkhpah is offline
It just makes me laugh every time I see it...BKH
