Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 03-29-2008, 09:48 AM
Andy Andy is offline
Default problems sending pms
Rob:
I just tried sending a pm to a member on the board, and it says that the message as been successfully sent. However, when I go to "my home" to verify that it has in fact been sent, it does not show up. It says that I have 0 sent messages.
Also, when I set the brower to "remember me" when I log in, it will only work for 2 or 3 days. Then I have to re enter my password. Is this somthing that the board does, or is their an error in my account? All other forums that I belong to remember my username and password every time I enter their site. My browser cookies are always set to medium so the the computer is able to recoginize what I put for my username and pw.
thanks,
Andy
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Old 03-29-2008, 07:44 PM
Chevy454 Chevy454 is offline
Default Re: problems sending pms
Andy: you have to check the "I want to keep a copy" box to save your sent messages. As for the login deal, for some reason your computer is expiring the cookie from...if it works for a few days, then it should work indefinitely.
Old 03-29-2008, 08:36 PM
x  Baldwin  Motion's Avatar
Also, when I set the brower to "remember me" when I log in, it will only work for 2 or 3 days. Then I have to re enter my password.... Andy
Most operating systems have a setting for "cookies" in amount of space that is used to store them, try increasing the amount of space used for storing cookies. (This should only be required if you are not logging in every day.)
to change cookie settings in a windows operating system select "tools" then "internet options" then "temporary internet files" (cookies). then "settings" you may increase the amount of storage space for cookies which will extend the time between logins. I am not a computer expert, my kids told me this. This may also make the lights dim in the garage.
Old 03-29-2008, 08:49 PM
Thanks for the help guys. The login issue is the same on both my desktop and laptop. I'll try to increase the size for the cookies to see if it will retain the information needed for this site.
Andy
1972 Duster 340 727
Old 03-30-2008, 06:32 AM
Just a heads up here....
Also remember that if you keep copies of your sent messages, it affects the total amount of messages that you can have (99) before your PM box is full.
For example...if you have 35 messages in your "inbox" and 55 'sent messages' in your sent box....that equals 90...so you only have space for 9 additional messages...before your box is full
Old 04-08-2008, 08:21 PM
SSJunkie68-69 SSJunkie68-69 is offline
good info.....I thought it was 100 in each box....thanks for setting the record straight Bruce.
Old 04-08-2008, 09:06 PM
PeteLeathersac's Avatar
My Sent and Inboxes seem to hold 99 or 100 in each...total 198/200 before full?.
Perhaps try sending a bigger donation and see if that helps?.
The login remembering thing is something I've simply gotten used to..
Sometimes it sticks and remembers me for weeks...other times not even an hour?.
The long threads thing (like the 100 pg. Rotting Musclecars) where I need to click through the pages by tens is something I've never resolved?.
I tried changing settings to every seemingly possible way but no differences?.
~ Pete
