Old 03-26-2008, 06:03 AM
gtomike1966 gtomike1966 is offline
Default Frame Rail?
Hi,
I have been looking to buy a 67 to 69 Camaro. I have seen alot of ads stating the cars frame rails are good or the cars frame rails need work/replaced. I have owned GTO's in the past so this frame rail thing is new to me.
Can somebody give me a quick lesson in frame rails and what to look out for in a car? I understand that Camaros are Unibodys? And they have a front detachable frame (forgot what you call it) but I thought the rest of the body was all one piece except for the obvious doors and trunk lid.
Thanks!
Old 03-26-2008, 06:15 AM
Default Re: Frame Rail?
Run along the rear floor boards and on either side of the trunk area to the back. If you take the back wheel off of a camaro, firebird, nova etc it will be right in front of you. They are prone to rust but they make a couple types of repair kits for them.
Old 03-26-2008, 07:51 AM
Kurt S Kurt S is offline
That's the problem, they are part of the unibody and it is some work to repair them.
Kurt S - CRG
Old 03-26-2008, 07:53 AM
The area that usually rusts out first tends to be around the rear spring eye. If you squeeze it, (the frame in that area) and it moves, or makes a crunching sound, there's most likely an issue.
Old 03-26-2008, 09:51 AM
FRITO FRITO is offline
hey you guys can u help me i got a new project nova JUST GENRAL INFO LIKE WHAT IT WAS FACTORY I TRADED MY BOSS LADY CADDY FOR IT IT HAS A TAG ON FIRE WALL SAYS ST 69 WRN 11427 THERE IS A 53 53 BELOW THAT ON THE INSIDE IT HAS A PLATE WERE THE RADIO WAS ON MY OTHER NOVA HAS 12 BOLTS IN THE REAR COVER OF REAR END TRANNY WAS IN THE TRUNK HAS A TAG THAT IS STAMPED CY -69 ON THE DRIVERS SIDE OF TRANNY IT CAME WITH A BIG BLOCK ON A STAND SOPOSSED TO BE THE ORIGANAL MOTOR AND IT HAS GILLS ON THE SIDE LIKE A FISH tho motor has a casting number 3963512on the back driver side
head has acasting number of 3946074 alumunim has the factory intake its ulumunim and has funny lil snow flake casting on it does this help i hpoe its worth tho caddy i traded
GOT A NOVA NEED INFO PLEZZ
Old 03-26-2008, 05:56 PM
So the frame rail is actually attached to the body, unlike a GTO in which it is actually a separate part.
It sounds like if you have a bad frame rail its is a pretty big job to fix. I will need to make sure I check any potential cars for a solid rail.
Thanks for all the replys, it was really helpful.
PS. I assume FRITO is not asking real questions because NOBODY seriously has that bad of grammer, puntuation and spelling.
Old 03-26-2008, 06:15 PM
Frame rails can be fixed, replaced, or repaired. Most of the time the decision is whether the car is worth it. A nothing special 6 cyl car might not fall into the fix catagory, while a real Z, or SS 396 car most likely would.
Old 03-26-2008, 06:23 PM
Frito, can you post some pics? If you have trouble, send them to Bruce, Xplanetdad. He'll help you.
Where exactly are you in Ok, and feel free to pm me your phone number. I'll help you as best as I can.
Old 03-26-2008, 07:23 PM
John Brown's Avatar
and is still able to hit the space bar between words...........
John Brown
Old 03-26-2008, 11:10 PM
x  Baldwin  Motion's Avatar
..........If you have trouble, send them to Bruce, Xplanetdad . He'll help you.........
"X-planet Dad" sounds like a super-hero!!
