Old 03-21-2008, 06:52 AM
iluv69s iluv69s is offline
Default THE LAST??? 1967 Z-28
This is the last production dated 1967 Z-28 known to exist. Of the 200 or so 67 Z's in Jerry Macniesh's registry, I believe this is the only 07C car known and most likely the only one ever made. Just a few hundred cars from the last VIN.
Original white car w/black stripes , low option... cowl plenum cut-out in firewall.
This car shows 17,000 original miles. I have no original paperwork. Selling as a roller..no motor or trans...but otherwise mostly complete...original front discs now changed to drums(this was a common drag racing change as the discs created too much drag)...car has an original 12 bolt w/the bracket(although the bar is missing)..4.10 posi...but not # matching or original to the car...
body extremely solid with original quarters and perfect floors and trunk and rockers,etc....resto. began..needs finished....easy finish...
will be listing on Ebay Sunday...buy-it-now 45k as roller.
Will offer, (to buyer of car only), NOS Smokey Yunick ,mostly complete, MO302 motor that was purchased at his auction. Motor has original GM "born-with" MO assembly stamp but was never VIN'd. Car w/motor 55k buy-it-now.
thought I'd offer it here for a few days first... Thanks Yenko.net...
max
Attachments - The Supercar Registry 330274-167asspicresized.jpg 328867-Cnv1803.jpg 328767-67MO302wcowlplenum.jpg 328765-67MO302carbdate.jpg
Old 03-21-2008, 06:09 PM
Default Re: THE LAST??? 1967 Z-28
07C cowl tag
Old 03-21-2008, 06:53 PM
firstgenaddict's Avatar
What are the dates on the MO engine?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 03-21-2008, 08:55 PM
heres a pic of the stamping...off the top of my head, I don't know any of the other dates...but i can tell you what I remember when I bought it...I will check the numbers if needed...I believe everything is correct and dated correct, less the distributor ...and for some reason I believe the intake was not correct off the top of my head...(both 69's) but according to the docs. I recieved with the motor, everything else is correct, dated and new...carb, heads, etc...apparently Smokeys motors were torn apart and rebuilt before the auction...
Old 03-21-2008, 08:57 PM
Here is a pic of the whole motor...it is actually as I purchased it with the Smokey docs. and all...
Old 03-21-2008, 09:05 PM
PM sent
~JAG~
NCRS#65120
Old 03-21-2008, 10:39 PM
quick-bowtie quick-bowtie is offline
Any body pics??
69 NASCAR PACECAR Camaro 1 of 7
68 Shelby GT500 Convert
Some other GM and Mopar
Old 03-22-2008, 12:20 AM
William William is offline
Close but not close enough.
There is a Z/28-RS nearby within 100 #s from the last '67 produced at Norwood.
Old 03-22-2008, 01:56 AM
Yes William..but that is an 07B car I believe...I believe there are a few 07 B Z cars...I was told there are only a handful of total 07C cars known in the CRG database....but please correct me if I am wrong... I do not have access to the database(or any database for that matter)..I'm going by what I was told a few years ago by Jerry....I assume my car was held up on the assembly line for some reason?? Don't know...??? Do you know for sure that this other car is an 07C car?? I'd like to post my ad on Ebay accurately...Thanks, Max
Old 03-22-2008, 02:49 AM
What matters is the VIN as that establishes when the car was built. I do not believe this car is in any db.
