Old 03-20-2008, 03:25 AM
HEMIBEE HEMIBEE is offline
Default Build sheets (is laminating a good idea)?
Just looking for idea's on preserving build sheets, is it good to laminate these, or is there a better way to be able to view these and not damage them any further, the laminate sheets I have are sticky and ounce they are done, they are DONE.
Rich Straub
raiv 69 judge, ra3 70 judge, 71 judge,74 SD trans am,71 cudas, 67 189 Corvette roadster, Quicksilver 68 HURST
z-10 396 camaro, 69 HEMIBEE
Old 03-20-2008, 03:44 AM
Mr. Chevy's Avatar
Default Re: Build sheets (is laminating a good idea)?
I would make a very good photocopy of it and then laminate that. I think if you keep the original tucked safely away, dry and out of light it should keep preserved.. I just don't like the idea of laminating the original because, like you said, once its done, its done...
Rich
Old 03-20-2008, 03:45 AM
Unreal Unreal is offline
I wouldn't. I'd either encase them in acid free vinyl or encase them in glass.
Old 03-20-2008, 03:54 AM
firstgenaddict's Avatar
Archival quality sleeve and keep it out of the light...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 03-20-2008, 04:46 AM
I have taken high resolution photos of mine and then put them in a protective box and tucked them away in a safe (fireproof).
you can reproduce them with your computer, blow them up Etc. My concern would be once they are laminated how would you prove they were original???
Carl
Old 03-20-2008, 05:12 AM
thanks guys, thats what i thought also, I have seen many a build sheet in laminate and didn't think he was to good an idea..
Rich Straub
Old 03-20-2008, 05:19 AM
67rscoupe 67rscoupe is offline
get a plastic sleeve for it.i have seen plastic sleeves for documents.there stiff so they will not bend.
Old 03-20-2008, 11:51 AM
m22mike's Avatar
m22mike m22mike is offline
If your near a sports card shop, they will have the plastic sleeves too.
Mike
Old 03-20-2008, 06:48 PM
gtomike1966 gtomike1966 is offline
You could scan it and then print it on a nice color printer then laminate it.
The quality of scanners and printers these days is pretty impressive.
If you dont own a scanner/printer im sure a Kwik Kopy or similar store will do it for a small price and they can probably laminate it too.
Old 03-23-2008, 04:10 AM
Mike
yes, that a good idea.
