Old 03-19-2008, 05:10 AM
Default Flywheel
Can someone tell me what this flywheel decodes to and what it is dated?
-Dave
http://cgi.ebay.com/ebaymotors/ws/eBayIS...AAQ:MOTORS:1123
Old 03-19-2008, 05:45 AM
John Brown's Avatar
Default Re: Flywheel
11" OEM High Performance GM Flywheet Casting # 3973456 N. GM part# 3973456. Nogular Iron, Weight 28.4 LBS. Dated January 6, 1955?, 1965?, 1975? .
John Brown
Old 03-19-2008, 05:50 AM
Thanks very much John. Can I ask, what book or data base did you use to decode that flywheel?
-Dave
Old 03-19-2008, 06:08 AM
It looks like a January,6th,1975 date to me,used on all internally balanced Small Block & Big Blocks.
How many teeth are on it..168?..If so that was superceded by Flywheel #3991469 later on & to be used on ALL 1967-85 internal balanced engines w/11" clutch & 2pc. rear seal.
Old 03-19-2008, 06:14 AM
Yes its 168 Tooth.
Old 03-19-2008, 06:43 AM
The part number: 3973456 tells you that it probably had to
be from a design, or modification sometime in the 1969
model year.
Nuch
Old 03-19-2008, 07:56 AM
John Brown's Avatar
-Dave
To tell the truth, even though I do have the dealer catalogues to look it up, I just typed into Google~
3973456 flywheel
~and came up with this.
http://forums.corvetteforum.com/show....php?t=1857077
I must be getting smarter, or maybe just lazy.
Next time I'll do a spell check when I copy information or something from someone else though.
John Brown
Old 03-19-2008, 06:38 PM
Wow. I never thought to Google something like that.
Thanks again,
-Dave
