Old 03-10-2008, 08:05 AM
COPO COPO is offline
Default 12 Bolt Casting # Help
Have a 12 Bolt for leaf spring car with casting # 3969841 Anyone know what this fits??
Old 03-10-2008, 08:31 AM
Default Re: 12 Bolt Casting # Help
I think you mean 3969341,which came in 1970 Camaros w/12 bolts.
Old 03-10-2008, 06:03 PM
Thanks Rick! I guess that explains why I couldn't find it. Better check my glasses prescription.
Old 03-11-2008, 07:24 AM
Jeff H Jeff H is offline
Got a date and code on that rear? I'd love to grab a COX 3.55 posi housing for my L78 car.
Old 03-11-2008, 05:24 PM
I'll check today.
Old 03-11-2008, 09:27 PM
69L72RS 69L72RS is offline
It could be a late 69 Camaro or a 1970 Nova rear.
Here is what I have determined from the data that I have collected.
1. Late 69 Camaros and 70 Novas shared the STANDARD option CB_ coded housings using the 341NF center casting, for almost all axle codes.
2.
3. 70 Camaros used different codes to differentiate the housing change in size.
The revision from 860NF to 341NF center castings was around late June of 69. I have them being used in housing assemblies as early as the first week of August 1969 in Camaro rears. Hope this info helps.
Old 03-12-2008, 02:15 AM
The casting date is F-21-0. It looks like "BM" then a 1/2" space then "W" then some numbers. Any thoughts on that, not something I've seen before, but looks factory.
Old 03-12-2008, 02:30 AM
Sounds like a late 70 Nova build or possibly a 1971 Nova 3:31 Open.
W would stand for Warren,Mi. plant.
I had heard these coulda be used a lil longer then 70,as well as used on the Nova too but not sure.
Do you notice the letter C anywhere in front of the BM stamping?
Can you measure the axle tube flange to flange?..is it 54-1/4 or 55-1/4?
Is the measurement between the centerline of the spring seats 42-7/16 or 45-3/8?
Old 03-12-2008, 02:42 AM
Did Novas get 12 bolts in 71? I thought everything was 10 bolt except pontiacs and trucks after 1970.
Old 03-12-2008, 02:48 AM
Check those measurements I posted and let us know what you find.
