Old 03-09-2008, 06:10 PM
JOZW30 JOZW30 is offline
Default Electrical question (72 Olds W30 w/455)
Had this issue start late last season.
Car starts OK, but sometimes my "GEN" idiot light comes on and goes out after a couple of revs. It also occasionally comes on during the first couple of miles of driving after cold start up.
Usually when I am slowing down for a turn and I've got the clutch engaged.
Also, seems like the headlights are not very bright. No dimming up and down with engine speed (halogen lamps). measured 12V at socket with headlight switch on.
Battery is new.
Any thoughts?
Also, if I want to rebuild my original alternator, is it hard to do and where do you get the correct parts?
Joe
Old 03-09-2008, 06:56 PM
Default Re: Electrical question (72 Olds W30 w/455)
I would check all grounds and wiring. Then any good alternator shop can rebuild your alternator. If you think you need more than a good rebuild and clean, you can have a professional restorer do it. How low is your engine idle?
