Old 03-07-2008, 02:04 AM
Stefano Stefano is offline
Default October Built 1969 Camaro
The front springs of this 1969 Camaro seem to have been in place a long time. It is an early October of 1969 (late) built car.
What Color tags were used on 1970 Novas and 1970 Camaros?
[image][/image]
Old 03-07-2008, 02:44 AM
Nova Jed Nova Jed is offline
Default Re: October Built 1969 Camaro
My June built 70 Nova has a blue or yellow tag if I am not mistaken.
Old 03-07-2008, 04:02 AM
firstgenaddict's Avatar
Stefano... that is the same spring and tag that was in the 69 RS/Z survivor!
[image][/image]
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 03-07-2008, 05:17 AM
James,
That is interesting. I don't ever remember seeing a yellow tag on a Z28, they were blue?
Looks like the same part number from what is legible.
Does anyone have that spring application??
What is the build date of that Z28?
Thanks for posting.
Old 03-07-2008, 07:46 AM
I'm showing front coil spring #3955725 was an HB suffix code recommended on the 1969 Camaro:
*Model 12367 with Heavy Duty springs and base engine when front weight was between 359-440lbs.
*Model 12437 with Heavy Duty springs AND base engine AND JL-8 brakes when front weight was between 345-426lbs.
*Model 12437 with Heavy Duty springs and either L-35,L-35,L-78 engine when front weight was between 345-426lbs.
*Model 12437 with Standard springs and either L-34,L-35,L-78 engine when front weight was between 345-426lbs.
*Model 12467 with Standard springs and either L-34,L-35,L-78 engine when front weight was between 263-344lbs.
*Model 12437 with Heavy Duty springs and either L-48,L-65 engine when front weight was between 345-426lbs.
*Model 12437 with Heavy Duty springs with Z/28 when front weight was between 263-344lbs.
*Model 12467 with Heavy Duty springs with Base engine,but NOT JL-8 when front weight was between 263-344lbs.
Old 03-07-2008, 08:06 AM
Great info.
The Camaro does have a big block in it. [image][/image]
Old 03-08-2008, 04:36 AM
The Z is an 04C.
The options may push it to the 263# threshold for the springs. Endura, RS, Cowlhood, Console, instrumentation... etc.
I will also have to check the vintage certification sheets for the car. They never mentioned the springs when the car was being certified.
~JAG~
NCRS#65120
Old 03-12-2008, 09:58 AM
Kurt S Kurt S is offline
James,
What was the broadcast code for that tag on the Z?
Kurt S - CRG
