Old 02-24-2008, 06:13 AM
ssdanny69 ssdanny69 is offline
Default 1969 Dodge Charger R/T
Helping a friend sell a 1969 Dodge Charger 440 R/T, 4sp, Dana, 2 owner car that's RUST-FREE. Medium Green Metallic, Black Vinyl Top, Black inerior, console. This is truly a great car to restore. Everything on the car is original with the exception of the tires. Car has been in storage since 1980. Original owner purchased the car at Preston Dodge in Dallas and the dealership is still in business. Monor surface rust in the trunk due to the trunk mat but there are no holes. Looks great from underneath. Only bodywork done to the car was at the top corner of the driver's side bondo (only bondo on car). Quarters, floors and rear window panels are perfect! Clear Texas title in second owner's name dated February 1970. Grill is in perfect shape. Car has several door dings. Original fender tag, matching numbers car (original drivetrain). Car was last started and moved December of last year. Car was leaking a little oil from sitting and previous owner tried to remove the oil pan to replace the gasket but did not realize that the engine had to be lifted to remove the oil. He decided to drain all the oil instead. Hooked up a battery and removed the coil wire and the car turns over immediately. Everything is original except tires and plug wires. Tag is still on the rearend, factory markings, etc...great car to restore for the Mopar collector
Please email or call me at 972-412-2972. $22,000 firm.
Thanks!
