Old 02-15-2008, 08:56 AM
Default Oil plug for 4 bolt block?
I'm trying to figure out what the plug should look like, that fills the large, by the oil filter on a L-78 4 bolt main block. Is this the correct style, or should it be the type that would be tightened with a 1/2" socket extension?
69 El Camino
69 Nova
C7 Vette
Old 02-15-2008, 09:12 AM
John Brown's Avatar
Default Re: Oil plug for 4 bolt block?
Shouldn't the oil pressure line go into the center of that fitting??
John Brown
Old 02-15-2008, 06:09 PM
No. The large hole gets a plug. There are 3 holes. The hole on the left gets a fitting for the oil pres gauge. The hole on the right is clutch linkage, and the center hole gets a plug that looks like the one in the pic above ????
69 El Camino
69 Nova
C7 Vette
Old 02-15-2008, 07:09 PM
nrjulin nrjulin is offline
Bill,
My 70 L78 has that style plug.
Here is a picture before being rebuilt. As you can see it was not the target of my photo (tried to get VIN) but it is visable.
I am sure others will offer thier knowledge as well.
Nils
Old 02-15-2008, 10:58 PM
3macs1 3macs1 is offline
Did the 69 4 bolts use the plug with the "W" cast into it like earlier years?? I remember the 66/67 L-72 with the "W" plug.
