Old 02-14-2008, 03:09 AM
68 Vert 68 Vert is offline
Default '71 LT-1 'Vette
I'm trying to find misc. part/casting #'s for these cars; block casting, heads, carb/smog etc. I've done some web searching and didn't come up with much.
The car I'm looking at is a; 4sp(M21), special order axle, pw, AM/FM, PS and PB. It does have a tank sticker.
Any help is greatly appreciated.
Mike
Old 02-14-2008, 03:39 AM
GaryH GaryH is offline
Default Re: '71 LT-1 'Vette
Here are some numbers off of mine. The exhaust manifolds and distributor are not original but I am pretty sure the rest is:
Engine ID code VO825CGZ
Block casting 3970010
Block casting date H200
Cyl head casting 3973487
Cyl head casting date LH 190 RH 200
Ex. Mnfld Casting # LH 3822765 L10 RH 3932461 L15
Intake Mnfld Casting 3959594
Dist 1112038 0H4
Holley 3989021 4150 082 R4801A
Rear Axle 411 Code AC Posi
Trans M21 3925661 C11510 Date P1K20
Rad 3018802
Heater Blower Motor 4939300 5044753 Date 2-0-2
Horns 9000245 Date 0B3
Vacuum Tank 3966704
Gary
71 LT-1 Vette
85 IROC (Modified)
09 SRT8 Challenger 6sp Kenne Bell on the way
Old 02-14-2008, 04:43 AM
Wow, that was quick, thanks Gary. Did the LT-1's have unitized ignition in '71? Flex fan or clutch fan? The car I'm looking at looks like it should have a smog pump, is this correct?
Again, thanks for any help with the questions.
Mike
Old 02-14-2008, 06:19 AM
LS6 RAT LS6 RAT is offline
Mike,
The '71 LT-1's came with a magnetic pulse transistorized ignition system, this included a special TI coil, TI distributor, TI amplifier and special wire harness.
It does use a 5 blade fan with either a eaton or schwitzer fan clutch.
All LT-1's for '70, '71 & '72 came with A.I.R. emissions system, which included bracketry, air pump, diverter valve, manifold pipes & assorted hoses.
2 1971 LS-6 Corvette coupes (Duntov's last stand)
Old 02-14-2008, 05:21 PM
Mike,
Thanks for the info, the air pump is missing but everything else looks to be there. I have to check on the TI and see if it still all there.
The tank sticker has all of the options and paint code on the car except it shows a black interior, the body tag shows tan leather which the car has...sticker looks legit. Could the tank sticker be wrong?
Sorry for the questions...I'm just trying to get educated in the 'Vette world.
Mike
Old 02-14-2008, 06:59 PM
Can you post a pic of the tank sticker?
Gary
71 LT-1 Vette
85 IROC (Modified)
