Old 02-09-2008, 11:45 PM
blackls6 blackls6 is offline
Default Correct Clutch Fans for LS-6?
I was told there are two correct clutch fans for the LS-6's.
I have one with no part numbers, it has seven blades, four rivets, has a H, 3, and Front stamped on it. Is this a correct one? My friend says no he says the 772 fan is correct! Can anyone help me solve this mystery? Need photo's.
Thanks! John
Old 02-10-2008, 01:15 AM
Rick Cell's Avatar
Rick Cell Rick Cell is offline
Default Re: Correct Clutch Fans for LS-6?
My Atlanta built LS6 has an 064 fan.
Old 02-10-2008, 01:28 AM
3macs1 3macs1 is offline
Thanks! John
I thought I read on this site on a past posting that many of the ls-6 fans were not stamped with a part number but were the 772 style. Rick (ss427) will hopefully confirm since I believe it was his feedback. My LS-6 fan is not stamped with a part number but my ls-5 one is a 772. They look the same side by side.
Old 02-10-2008, 02:57 PM
Rixls6 Rixls6 is offline
I believe the 064 fan is for the 4.10 gear cars only, and the 772 fan for the 3.31 geared cars.
There may be two different style 772 fans, not counting the numbered and non-numbered. I will check a couple I have, but seems to me there was a squared off center hub, and a pointed center hub style. By that I mean the area where the blade is riveted. I'll get some pics today to show this.
Rick
Don't text and drive.
Old 02-10-2008, 04:31 PM
Rick Cell's Avatar
My LS6 car Atlanta built has the 331 gears and the 064 fan.
Old 02-10-2008, 04:44 PM
That goes against what I've heard. Is the car all original and documented to be that way?
Rick
Old 02-10-2008, 04:49 PM
Rick Cell's Avatar
Documented with build sheet and has the original fan.
Old 02-10-2008, 08:39 PM
Maybe Rick Nelson can shed some light on this. It's the first one I've heard of built that way.
Rick
Old 02-10-2008, 08:55 PM
Rick Cell's Avatar
Rick the fan is dated Dec 69. My car is an April build.
Old 02-11-2008, 02:07 AM
slimsls6 slimsls6 is offline
my unrestored ls6 has 3:31 gears and was built in kansas at leeds plant has the 064 fan
*70 LS6 M-22, unrestored, original born with, special ordered orange.
* 72 nova 557ci, LGT700 5 speed, AFR heads
, Tunnel ram W/ dual 750's, 723hp/690tq, 2 1/8 Lemons
