Old 02-08-2008, 11:47 AM
Default 1969 Chevelle KG L89 block found
I've come across a 69 L89 block and I'd like to help reunite it with the car it came with from the factory. The stamping on the pad is T1003KG and there's a VIN by the oil filter.
If your 1969 L89 Chevelle is missing its original block... PM me with details and we'll determine whether it's yours. If so, I'll give you the owner's name and number.
Old 02-08-2008, 03:50 PM
John's Avatar
John John is offline
Default Re: 1969 Chevelle KG L89 block found
...is that an "Aluminum Head" block?
Old 02-08-2008, 04:28 PM
Yes...it is
Dan.
Old 02-08-2008, 05:33 PM
You have a PM.
Old 02-09-2008, 12:07 PM
You have a PM.
Thanks for the heads-up! It's good of you to be on the look-out for someone else like that
Old 02-09-2008, 07:56 PM
PeteLeathersac's Avatar
Helmet...
I expect you've tried running body style variations w/ the stamped Vin sequence through GM Canada Vintage Services already?.
~ Pete
Old 02-09-2008, 08:11 PM
This could be from an L-89 Elcamino originally too.
Very nice of you to offer this up this way.
Old 02-09-2008, 09:49 PM
Helmet...
~ Pete
Actually I haven't done that... I can't make out a couple of the numbers by the filter. Good idea, it's worth a try.
Old 02-09-2008, 11:32 PM
427king 427king is offline
Yenko Paid Member
Can we see a pic??
Old 02-10-2008, 12:02 AM
I'm afraid... people will pick it apart. The block has had some problems - its got two sleeves, and it's been decked a couple of thousandths but the stamping is still visible.
[image]
