Old 02-02-2008, 05:17 AM
Canuck's Avatar
Canuck Canuck is offline
Default Delco Moraine Brake calipers
When I restored my 71 W30 in 1996 I replaced the calipers with whatever my brake supplier could provide. I ended up with an aftermarket caliper on the right side and a correct date "Delco Moraine" caliper on the left. In an attempt to correct the error of my ways I am needing a source for rebuilt calipers that are factory correct,that is they must say "Delco Moraine". Failing that does any body know of a source that will rebuild a set of correct calipers I scored off a parts car. A local brake shop can install kits but I need the finish restored.Any tips?
Paul
www.vancouverclassiccars.com
Old 02-02-2008, 05:34 AM
3macs1 3macs1 is offline
Default Re: Delco Moraine Brake calipers
Paul
Hi Paul:
I would still not count out your local parts suppliers.If they will let you look I bet they still may have some of the delco ones on the shelf.I know we got a set not a year ago like that for a 69 impala.Worth asking them.
Old 02-02-2008, 05:44 AM
Canuck's Avatar
Most of the local suppliers order from a central warehouse. Two stores brought in a pair,they were all aftermarket. I asked about visiting the wareouse and was told it was not possible.
Asking one store to bring in the entire inventory might be a push.
Paul
Old 02-02-2008, 06:06 AM
Understand Paul. I am lucky I can just walk out back and look at most of the local shops. It was actually Canadian Tire where we got the last set. Of all places.
Old 02-05-2008, 12:49 AM
Unreal Unreal is offline
I got my long slot (732, I think) for my 499 distributor that way. I used to check at almost every parts store. (I say almost since I never stopped when my wife was in the car!!) A guy at O'Reiley's asked what I was looking for, and when I told him, he called all the other stores in the area, and asked them to check their stock. When that netted nothing, he ordered 3 distributors for me to check out. None was a 499, but one had the 732 cam. He allowed me to purchase the distributor, exchange the shaft, and return it.
Now that's a friendly parts store!!
