Old 02-02-2008, 03:25 AM
Mike Petrillo Mike Petrillo is offline
Default FIRESTONE F70-15 SUPER SPORT WIDE OVAL RED LINES
Nice, NOS, not rotted, Firestone Wide Oval F70-15 Tires!! These were mounted on a display car, then dismounted. They are like new. Not driven. Even have the original tags, although tags are unreadable. DOT Dated All 4 tires carry same DOT: CYU2F416308.. Built in 30th week of 1968.
have pictures can email..
$3500. Mike 707-246-4662
Old 02-02-2008, 06:46 AM
Default Re: FIRESTONE F70-15 SUPER SPORT WIDE OVAL RED LINES
Mike
Is there a small triangle after the 308?
Old 02-02-2008, 08:23 PM
Hi,
No triangle just molding plate markes on both sides of the dot
mike
Old 02-03-2008, 07:25 PM
AMANOCC AMANOCC is offline
Yenko Premier Member
Per Bizzoco's "1969 Stingray guide book" the 10 or 11 digit TIC (Tire Identification Code) didn't go into effect until May 22 1971, from 1969-71 the codes where only 8 digits....Maybe your tires where made in 1978?
Old 02-04-2008, 04:10 PM
I will investigate but i do not believe bias ply tires were made by the major company's for passenger cars that late as radials were introduced in the early 70s only the smaller company,s like kelly springfield for private brand product.I will contact firestone and see what they can tell me.
thanks mike
Old 02-05-2008, 01:33 AM
I contacted firestone customer service # and they were no help so if anyone has more info that would be great.The tires are vintage aug 1968 or aug 1978 non repop.
Old 02-05-2008, 03:55 AM
------Mike,,,This may help or may not. How far out towards the tread is the stripe??? Early Firestone wide ovals had the stripe way out towards the edge and soon after the stripe moved towards the bead. I think it was because there was less flexing of the sidewall closer to the bead so ultimatly there was less seperation or cracks in the stripe. These early tires would be extremely rare and I expect valuable. If the stripe is early the tires are definetly 68 and not 78. Im not sure when the stripe migrated towards the bead but when I picked up my new 1969 Vette in early October the tires had already changed.......Bill S
