Old 02-01-2008, 07:25 PM
JHS JHS is offline
Default QR coil spring tag question
My 1969 Impala SS has the original QR tags on the front springs. Can anyone help me decode what that code represents? It is an L72 car with a NOM "CE" 512 solid lifter block . Just wondered if these tags might further verify a true L72 as the car has no POP or build sheet.
'70 L78 NOVA SS
'77 Bronco
Old 02-01-2008, 07:37 PM
Default Re: QR coil spring tag question
QR had multiple applications,nearly 17 just on the 1969 Passenger series alone.
Ranging from the docile base spring on the 15311 models,all the way up to the F-40/F-41 recommended on the L-72 Z-24 models.
Can you be more specific on your cars given options,and model number?
Old 02-01-2008, 07:50 PM
PeteLeathersac's Avatar
Remember last year when 'Tony Scuncio' confirmed his '69 Biscayne was an L72 car...I thought there was something to do w/ the coil tags being a unique #?.
Here's the thread;
https://www.yenko.net/ubbthreads/show...fpart/all/vc/1
~ Pete
Old 02-01-2008, 08:02 PM
Although L-72's got them,they were not L-72 specific.
Old 02-01-2008, 08:43 PM
Hmmm...interesting..
Thanks Rick!
~ Pete
Old 02-02-2008, 12:18 AM
JHS JHS is offline
QR
Custom Coupe, 512 CE solid lifter engine, M21 w/VIN, correct 3.31 posi, single return fuel line, SS model w/ bucket seats and orig. Hurst shifter, front disc brakes, ps, pb, am, 8-track. What else is applicable?
Original owner (1969-2003) and the selling dealer gave sworn affadavits the car was an L72. The engine was removed in mid-70's due to gas prices and long gone.
'70 L78 NOVA SS
'77 Bronco
Old 02-02-2008, 01:15 AM
Tony's flicker pics are still alive and looking closer it appears it's the rear 'DW' sping tag he's mentioning as unique to the L72...Rick?.
Sounds like a cool piece Joe...no chance it's a Canadian built car?.
~ Pete
Old 02-02-2008, 01:49 AM
scuncio's Avatar
scuncio scuncio is online now
The information I have only confirms that a BELAIR or BISCAYNE equipped with QR/DW springs is L72. In other words, the only QR/DW combination in the Belair/Biscayne spring charts is found with the 'L72' option. I am not sure if the QR/DW combo is used in other engine applications for Impala/Caprice. I'll dig up the information I have to see if it contains Impala/Caprice application info.
Just FYI, the new owner of my old Biscayne has been able to trace back the ownership of the car and hopefully it will yield even better documentation of its history. I am glad it went to a great home!
Tony
Old 02-04-2008, 05:08 PM
JHS JHS is offline
The VIN starts: 164479Jxxxxxx so it is not Canadian, could not be that lucky...
'70 L78 NOVA SS
'77 Bronco
Old 02-04-2008, 08:01 PM
For 1969 Chevrolets,the QR Front & DW Rear coil springs were only used together on the following model numbers when optioned as such:
*Models 15411/15611 w/RPO L-72 w/front weight 0-172lbs. & rear 0-106lbs.
*Models 15469/15669 w/RPO L-72 w/front weight 0-156lbs. & rear 0-50lbs.
*Models 16337 w/F-40 suspension w/front weight over 308lbs. & rear 0-160lbs.
*Models 16437/16447/16467/16647 w/F-40 suspension w/front weight 209-268lbs. & rear 0-72lbs.,AND these same 4 models w/L-72 engine w/front weight 199-258lbs. & rear 0-101lbs.,AND these same models w/RPO Z-24 package with front 199-258lbs. & rear 0-101lbs.(excluding model 16647)
