Old 01-10-2008, 07:48 PM
provette67 provette67 is offline
Default 409 carb id help
are these correct dual quad 409 carbs? what year will they work on? I thought that they should be 3804.Thanks in advance
http://cgi.ebay.com/ebaymotors/ws/eBayIS...47427%26fvi%3D1
Old 01-10-2008, 07:54 PM
John Brown's Avatar
Default Re: 409 carb id help
3361 (front) and 3362 (rear) were the earlier numbers. 3804 replaced the 3362 for 1964.
John Brown
Old 01-10-2008, 08:03 PM
Thanks for the info.I am just starting to work on one.What will a good set usually go for?How hard are they to find?What should I look for when looking at a set? I really put dual carbs on my carb.I think they look so cool!!
Old 01-10-2008, 08:16 PM
John Brown's Avatar
Well, carb rebuilders/restorers will pay up to $500 per carb, then re-do them and sell them for more. Make sure all the pieces are there when you buy them and that the bakelite choke housing is not broken. Pass on corroded carbs, imho. The carbs are available, if not exactly plentiful, so finding date codes you want shouldn't be too hard either.
John Brown
Old 01-10-2008, 08:19 PM
that is what I was looking for.thanks
