Old 01-10-2008, 06:06 AM
enio45 enio45 is online now
Default Radio Delete
If a 69 camaro car was ordered radio delete - did they still install the speaker in the front dash? Anything else they did not do when this was ordered - besides the radio delete plate?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-10-2008, 06:26 AM
William William is offline
Default Re: Radio Delete
No speaker; a cardboard cover taped to the underside of the speaker grille as shown on page 1 section B2 of the AIM. Also the hole for the antenna lead in the cowl was plugged.
Old 01-10-2008, 07:47 AM
Thank you for the info. So if i believed i had an original fender on a car with the antenna hole in it - i should assume a radio was installed?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-10-2008, 07:58 AM
camarojoe's Avatar
There was no antenna hole in the fender on a radio delete car, just a plug in the door jamb/cowl area where the antenna cable would pass through and a cardboard speaker cover, as William mentioned. If its defintely the original fender, and an original antenna hole, it had a radio. Look closely at the hole though, as alot of radio delete cars ended up with aftermarket radios and antennas later on.
Joe Barr
Old 01-10-2008, 08:05 AM
Joe, thanks for the info - when you say look closely at the hole - is there something special with the hole i should notice. I was told that orig fenders with the antenna hole have the circle with a notch in it. Is this what your referring to?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-10-2008, 08:10 AM
------Ed,,,Im fairly sure that the ground straps under the hood were also missing from a no-radio camaro........Bill S
Old 01-10-2008, 08:39 PM
I bought a new '65 Chevy II radio still in the box many years ago. It had all the ground straps plus two spiral pieces that fit inside the front hub dust caps. Something about grounding the hub to the spindle. There were also some capacitors/condensers for static suppression. I think Bill is right about the ground straps as I don't recall any off the back of our engine to the firewall. I don't remember the exact details any more. It was a long time ago.
Old 01-10-2008, 09:06 PM
3macs1 3macs1 is offline
I am suprised all of that info would not be in the assembly manual. I know it is for 65-70 fullsize.
Shows exactly what to add and where when installing any of the optional radios so easy to figure out what came with a delete car
Old 01-10-2008, 09:15 PM
ORIGLS6 ORIGLS6 is offline
I know this tread refers directly to Camaros but I had a '68 Corvette with no radio. I still have the 'build sheet' from the top of the fuel tank and it was definitely a radio delete car. No ignition shielding under the hood, no braided plug wire covers, no speakers, the block off plate in the dash,................... but the car came with an antenna and the coax run under the console to the dash.
I bought the car in December of '71 and talked with the original owner. He told me he NEVER had a radio in ANY of his Corvettes. His earlier cars ('58 & '62) received record players and his '64 and up cars had tape decks. He traded the '68 for a '72 and still, no radio.
He told be he was upset with the dealer when he first saw the '68 because he noticed the antenna on the car as he drove on the lot and assumed it had a radio. He asked if they could remove the antenna but finally decided to leave it rather than patch the hole in the rear deck and have the panel repainted.
Old 01-10-2008, 09:50 PM
mockingbird812's Avatar
Wait a minute Dennis ! Are you suggesting that the procedures were NOT standardized by the General?! Such blasphemy.................
Sam...
