Old 12-20-2007, 09:04 AM
enio45 enio45 is offline
Default Trim Tag- how to clean it
What is the best way to clean a trim tag? I have one that is very thick with paint - not sure what type of paint but i suspect its some type of harden enamel that was sprayed on the fire wall.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-20-2007, 05:30 PM
Default Re: Trim Tag- how to clean it
Ed,
Good ol lacquer thinner will do the job if you're in no hurry. Otherwise some low odor paint stripper will do the trick, brush it on the tag and watch the paint lift off the tag. The low odor stuff is fairly mild just remember to nuetralize it by washing the tag off with water when you're done.
Chris
Old 12-20-2007, 05:51 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
Were the trim tags not attached to the firewall BEFORE it was painted..therefore should not be bare metal.
Welcome aboard Chris! I missed your arrival to the board...good to get your thoughts on some of the subjects.
Howard
Old 12-21-2007, 05:45 AM
ok thanks chris - i have seen some restored cars with the trim tag painted and others not painted. I assume painted black is the correct way?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-21-2007, 06:08 AM
Painted tag is correct, but doesnt hurt to remove the existing paint if it is thick enough to the point where it is difficult to read.
After you clean all the old paint off, paint it black again.
TheMuscleCarGuys.com
Old 12-21-2007, 06:37 AM
Don't some early Camaro tags have white paint on them?
Charley, you out there???
Old 12-23-2007, 12:29 AM
Tarrytown SS427s Tarrytown SS427s is offline
It all depended on what the factory workers did. Some factories put a piece of tape over the tag before doing any painting, and others sprayed firewall black around the tag leaving the tag body color. And other factories of course sprayed over the whole tag when doing the firewall. I think it depended mainly on the factory, but also on the specific painter.
Steve
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
