Old 11-25-2007, 01:53 AM
JRSully JRSully is offline
Default Hurst shifter levers/arms
I need a hurst shifter expert here, I have a late model muncie (I think) and went to put standard hurst comp + shifter arms on it and the rectangular slot that fits over the tranny shafts is to small/narrow and the bolt to bolt them on is too wide to fit through the slot in the arm (confused enough now.?) I thought the Hurst/Chevy arms were universal, but I guess not. Anyway, any information is appreciated and if anybody has a couple of these laying around, I'm buying, Thx
71 Porsche 911 Targa
Old 11-25-2007, 04:20 AM
RPOL88 RPOL88 is offline
Default Re: Hurst shifter levers/arms
The arms you are using are for 1968 and down which uses the stud with a nut to attach the arm. Later style uses a bolt to attach the arm. Check to see all the connections are the same. Sometimes people just change the side cover for whatever reason. If you can tell me more about your application, I might have arms that will work. Also Summit carries replacement arms and you can check them out online.
Old 11-25-2007, 09:44 AM
crash crash is offline
There are different shift levers for different body styles, so knowing what your working on will help... All Hurst rods, levers, and mounting plates have part numbers stamped into them, what do you have??? Crash
Old 11-26-2007, 12:14 AM
Crash, the p/n's on the ones I have now:
1. 1052440 and 1052441 if that helps. Thanks for your help
Old 11-26-2007, 03:11 AM
You need shift levers 105-7058 and 105-7060, which are the bolt on levers that match your stud style levers... Hope this helps... Crash
Old 11-26-2007, 06:07 AM
Thanks much for the help crash. SULLY
