Old 11-11-2007, 04:41 AM
427TJ's Avatar
427TJ 427TJ is offline
Default 327 block date code help
Need help with numbers decode. Can't get at casting number with tall Moroso valve cover in place. Engine is in my '55.
Here's the block pad stamp:
Looks like casting date? Located ahead and above oil filter base.
Old 11-11-2007, 05:10 AM
kwhizz kwhizz is offline
Default Re: 327 block date code help
Here you Go!!......
EC 1965 327 Special high perf. - 300 4 Chevelle
EC 1966 327 A.I.R., glide - 275 4 Chevelle/1200
Ken
Old 11-12-2007, 01:04 AM
JohnZ JohnZ is offline
The casting date is on the passenger side rear flange of the block, about six inches outboard of the distributor.
'69 Z/28
Fathom Green
CRG
Old 11-12-2007, 01:18 AM
427TJ's Avatar
Thanks! I'll try to get at the casting numbers. Removing the valve covers should do it. I need to check the valve lash anyway.
